dnewton3
Staff member
Discussion = good.
Bickering = bad.
Knock it off or the thread gets locked.
Bickering = bad.
I really like the OEM vs High Efficiency debate. I can see both sides. Personally I choose filters that are high efficiency and high flow so I get the best of both worlds.You guys sure like to argue! It really is not a big deal, in the 1950's lots of car makers didn't even run oil filters on their engines. Who cares if they leak. As I said, Toyota prefers loose, leaky engine oil filters, they last sometimes 300,000 or more miles like that sometimes.
One reason Toyota oil filters irritate me. I will post this flashlight test, several filter companies use this style of bypass valve built into the leaf spring, It makes no sense to me that oil filter companies keep using this design, knowing unfiltered oil will go through, even with a brand new unclogged oil filter.
Now paying a premium for a “high efficiency” filter that has poor craftsmanship and defects is another debate…
Great question. I guess since I only do 5k oci’s I’d still go high efficiency knowing it won’t load up.Very insightful and I completely agree.
Let me ask you this, if you had to pick only one of those two attributes, which side of the fence would you be on? High efficiency or high flow?
What filters have so much dp vs flow that it's going to make an engine not receive adequate oil flow and lubrication? If you compared 10 oil filters with hot oil, and the dP at 8 GPM was only +/ - 2 or 3 PSI from the group average, then the flow difference when the DP pump is in relief won't really matter.Let me ask you this, if you had to pick only one of those two attributes, which side of the fence would you be on? High efficiency or high flow?
That may or may not be true. Toyota updated the media about two years ago:Probably a big factor on why the Toyota filters aren't very high efficiency.
Also, just because a filter is lower efficiency doesn't automatically mean it has a lower dP vs flow curve.
Looks like the bulletin is only for some specific cartridge filters ... not across the line. Who knows what the efficiency is of that media, doubt it's going to be drastically more efficient.That may or may not be true. Toyota updated the media about two years ago:
I was talking about the dP vs flow performance of the media itself, not the bypass valve. The bypass valve should be set according based on the expected dP vs flow with full loading and max oil flow conditions.there's this tsb for GM ecotec engines (1.5 and 2.0 I believe) where it's stated the bypass should not open below 15 psi dp, or you get extra wear. That wouldn't matter if the dp in reality was only 2-3 psi. But a leaky bypass valve sure would matter.
Of course, never said it wasn't. I said the bypass valve needs to be designed in accordance with the dP vs flow performance of the media, under the expected max dP situation of max expected flow and loading capacity. The goal of the bypass valve is to only open when it really needs to open. And the media cartridge itself needs to be designed to have a decent dP vs flow performance curve to start with. That's based on the design of the media itself, and the total media area of course. Increased media area helps both dP vs flow performance and holding capacity.but in a given application the dp IS determined by the filter media= size and flow
