Originally Posted By: Hokiefyd
Who knows, it may not have needed new dampers. Did you ride in or drive the vehicle to accurately judge his statement?
It probably did not "need" new struts. Neither did my Mustang. It didn't "need" new shocks or struts either. However, I "want"ed to replace what was in there with better shocks and struts because I believed that the handling of that Mustang would be improved by their replacement, and that is my desired outcome. (BTW, the new upgraded shocks and struts made a major improvement).
That the Camry owner couldn't, apparently, understand the concept of replacing suspension components for better handling is the real point here.
If he's happy with the ride of his Camry, so be it. However, making a comment about how he has never had to change the shocks and struts states a lot more about his preferences as a driver than it does about the reliability of his car or mine.
Quote:
This is a bit off-topic, but I believe that damper replacement is a bit over-rated.
I believe otherwise.
Quote:
Unless the dampers show signs of leaking or if they have an internal noise, they stay very functional for much longer than many believe.
Functional, yes, for some definition of the word.
It is my experience that shocks and struts do deteriorate over time, and I am sensitive to that deterioration. This deterioration is noticeable to me long before they get to the point of leaking or having an internal noise.
I am aware that many drivers do not notice this deterioration, or do not care about it. Perhaps they would rather spend the money elsewhere as long as the car rolls from point "A" to point "B". I expect that the Camry driver which is the subject of the previous post falls into that category.
