- Joined
- Sep 1, 2024
- Messages
- 1,161
I recently bought a 2009 Camry Hybrid. It's had a previous owner and it's due for an oil change. I'm going to change the oil but I've run into a problem. The oil filter that is on is 90915YZZN3. When doing research sources say the correct filter is either YZZF1 or YZZN1. I bought the YZZN1 from Walmart because Walmart doesn't have F1. It's saying that N3 has a different thread size than N1 so how can N1 or F1 fit if there is N3 on it and it has a different thread size? I'm confused and I'm not sure if N1 will fit. I'm not going to try it until I know for sure because that's my only vehicle.
- mattbruns3
- Forum: Engine Oil Filters
The 2009 Camry hybrid came with the longer Toyota filter F1 size, and of course the N1 can be put on, but it is the replacement for the shorter F2 filter. The F2 and N1 were not the original size. The N1 is even smaller than the F2.
The F1 can be bought many places and is the original size for that engine.
When someone says no I want to use the Toyota oil filters, I respect that.
Use the F1 oil filter to be true to the size it came with when new. There is no disadvantage.
