Unfortunately the car isn’t here right now, so I have to give the rough numbers. In April 2023 I changed the timing belt, and all related parts, as well as put a new oil pump from Toyota on the car to replace the badly leaking oil pump (which is ran by the timing belt). This oil filter was in service from April 17th, 2023 until roughly September, 2024, from 239,621 miles to roughly 244,600 miles with Mobil 5W30. There was lots of gunk in this filter as I believe I knocked a bunch of stuff loose while changing the oil pump, cam plug, valve cover gasket etc. I wrapped the filter in paper towels overnight to try to get a good look at the gunk in the pleats.
