Although it's only at 40,000 miles, the timing belt on the '01 Camry is 9 years old and I am going to be replacing it this weekend. I know I can get away with the belt snapping on this engine, but it's not going to be convenient to get a tow truck, etc. because you never know where and when it may fail.
Anyhow, below is my "shopping list" and as always, I was wondering what fellow BITOGers think of it. Anything missed out? Anything worth adding? Thanks!
- 1 engine mount (located above the timing belt cover, others are fine)
- Timing belt and tensioner
- Cam and crank seals
- Oil pump seal
- Coolant pump and gasket
- Idler pulley
- Coolant
- PCV valve
I'm thinking I might as well go ahead and replace the valve cover gasket whilst I'm at it. The thermostat and drive belts are still new, with less than 4 months on them.
- Oil pump seal
- Idler pulley
- Coolant
- PCV valve
