Hey folks I'm getting ready to shop for a travel trailer for my new 2017 F150 2.7. I was under the impression that the 2.7 was good to 8,100 per literature from fords website but upon a VIN search I see max tow at 5,000 but I'm just not sure that im interpreting it right. I no longer have the original sticker for the truck that would show what tow package I have, but it does have the larger mirrors, along with the 4 and 7 pin connector. Below is the info from a VIN search, I also know that I have the 3.31 gear.
Gross Axle Wt Rating - Front 3225 lbs 3225.0 min 3450.0 max
Gross Axle Wt Rating - Rear 3300 lbs 3300.0 min 3300.0 max
Curb Weight - Front 2548 lbs 2548.0 min 2726.0 max
Curb Weight - Rear 1846 lbs 1846.0 min 1895.0 max
Gross Vehicle Weight Rating Cap 6250, 6900, 6750, 6100 lbs 6100.0 min 7850.0 max (My door sticker says 6250lb)
Gross Combined Wt Rating 9800 lbs 9800.0 min 10100.0 max
Dead Weight Hitch - Max Trailer Wt. 5000 lbs 5000.0 min 5000.0 max
Dead Weight Hitch - Max Tongue Wt. 500 lbs 500.0 min 500.0 max
Wt Distributing Hitch - Max Trailer Wt. 5000 lbs 5000.0 min 5000.0 max
Wt Distributing Hitch - Max Tongue Wt. 500 lbs 500.0 min 500.0 max
Maximum Trailering Capacity 5000 lbs 5000.0 min 5000.0 max
Thats what came up from entering my VIN in a vin decoder. Can someone please help a newbie understand these numbers? Looking forward to learning here. Thanks.
