- Joined
- Dec 20, 2022
- Messages
- 310
This past February, I bought a ‘23 Chevy Blazer w/ the 2.0L and 9T60. I do a bit of towing with a small utility trailer and jetski, so I bought and installed a Curt hitch.
The Curt hitch has a rated capacity of 5000 lbs. The blazer, when equipped with the factory tow package has a rated capacity of 3250 lbs. From Chevy, the factory tow package does not add any extra cooling to the engine or transmission of the 2.0L.
I have a bit of yard work to do that will require me to rent a small tractor and a larger utility trailer. I will be right at the 3250 lb tow capacity.
Would you be comfortable towing the max factory tow capacity with an aftermarket hitch setup? Thanks!
As a side note, here’s a nice little table of GM transmissions in SUVs and their relevant capacities. It’s interesting to see how AWD has a lower capacity than FWD, especially when AWD usually comes with the 3.6 V6.
