I was doing a brake job (I changed the front pads and rotors of my Lancer) and while brushing one of the calipers, as I lifted it in order to brush the other side the Goodridge brake line I had installed, the hose formed a tight circle of a diameter of 0.4 - 0.8 inches close to its banjo fitting and it stayed at that position for a couple of minutes max.
- Is the brake hose that flexible or is it possible it got some kind of damage like cracking etc.?
- Is it possible that the connection of the banjo fitting with the hose got loose?
