its probably going to be phenomenal, but without a VOA, and UOA (data) this is only a guess.
reference:
ACEA A3/B4 Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & DI Diesel Engines, but also suitable for applications described under A3/B3.
ACEA A3/B3 Category is removed with the ACEA 2022 Oil Sequences. From ACEA 2016: Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & Diesel Engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of Low Viscosity Oils, and/or for severe operating conditions as defined by the Engine Manufacturer.
