Yes, you knew the snowthrower posts would start soon.
Last year I inherited a 1986 Toro 38080 snowthrower. This is also known as the 824. It has an 8hp Tecumseh. It's worked well for my dad over the last 20 years, started reliably for him by hand but it needs some TLC.
I hauled it out to start it up and do some fluid changes and other work on it and it wouldn't start. This isn't abnormal since it's been in my care but I've always been able to get it to run eventually. It seems that if you get it started quickly, it's easy to start, but if you have some trouble then it takes a LONG time. I found the source of a mystery fuel leak that presented at the end of last season that might be related to difficult starting.
In the side of the carb above the idle mixture adjustment is a small hole. This hole is pictured (but unlabeled) in the owner's manual carb photo.
Once primed this hole will dribble fuel by gravity/siphon. When priming fuel will shoot several feet from this hole. While cranking fuel will spurt from this hole in rhythm with the engine cycle. Today I could only get the engine to run on carb cleaner
I have some carb experience but not nearly enough to help myself without doing some research. I was planning on getting fuel line, a new fuel shutoff (both sources of slow leaks last year), a carb "repair" kit and then some elbow grease, fresh paint and fluids before this winter but something else is going on here.
Is something "downstream" of this point plugged up causing fuel to leave through this hole instead of air being drawn in? Or has something failed and fuel shouldn't even be there? Is there anything not included in the "repair kit" that I should order for general maintenance/rebuild? A float?
If there's any other forum sites I should join and inquire in, please let me know.
Thanks,
Craig.
Thanks,
Craig.
