MolaKule
Staff member
OK, we still see these terms commonly misused and interchanged even today.
1. Define a Mechanical Tolerance.
2. Define a Mechanical Clearance
This just proves that cats are smarter than people..they get burned once and dont repeat the mistake. People know the header is hot and still try to get their hand in there.quote:
Originally posted by sbc350gearhead:
Clearance........the distance between my oil filter, and my 400 degree header.
Tolerance......the time it takes for me to start cussing like a sailor when my hand exceeds the clearance.
There's another definition around here. Clearance is a town about 6 miles east of Paxton Illinois on Illinois Rt 9.quote:
Originally posted by MolaKule:
Yep, the guy from Illinois (Mr jsparp) nailed it.
Another term for Clearance might be:
1. space between adjacent parts,
2. the distance by which one surface clears another.
SBC, you crack me up; been there, done that!
I used to work with a chef who was fond of saying, "Didja ever notice how people will pick up something that's too hot to touch and put it directly in their mouth?"quote:
That's an unusual definitioln of "nominal clearance". Your "nominal clearance" would never occur unless the manufacturing process were out of control and a lot of parts were being rejected. Not exactly a nominal condition.quote:
Originally posted by lukey:
Very good guys......you're sharp!
But can anyone calculate the nominal clearance plus tolerance on the following 2 parts (this is a quiz but I'll give the correct
answer)
Shaft (be it a crankshaft journal or whatever) 2.250 +.000/-.001 Dia.
Bearing I.D. 2.251 +.001/-.000
Answer: .001 (nominal clearance) +.002/-.000
or put another way: a clearance of from
.001 to .003
So now you know as much as I do (but they pay me for stuff like that!)
LOL...................Lukey
Tarzan says clearances must have iuncreased!quote:
Used in a sentence:
Jane says the piston to bore clearance is out of tolerance according to the motor manual.
this is fairly common, and not unique to japanese carmakers. They learned it from european and american car makers. It was (and may still be) normal to assemble rings and pistons in this manner.quote:
Originally posted by wileyE:
Some of the japanese engine builders used to measure every part and mark them where they fell in tolerance. Usually ID'd as a A, B or C. Then upon assembly they could hand select for a very accurate clearance spec. Not sure if things are still done this way.
