Originally Posted By: cornfused
Originally Posted By: doitmyself
Even though your mileage is well below the 100K change interval, you have reached the 5 year "and/or" change interval.
If you choose to change only the radiator fluid, you will probably leave at least 1/2 of the total old fluid in the engine block. With this in mind, you should not wait another 5 years/100k to change out the radiator fluid again.
If the fluid is cloudy or otherwise looks "spent", consider replacing all the fluid. Follow the above advice about G 05. I don't use cleaners or chemical flushes anymore unless there is some kind of problem.
Maybe check some Ford forums. Aren't some models prone to heater core corrosion? If so, again consider replacing all the fluid.....cheap insurance.
Your case is a judgement call in my opinion, partly because you don't know the prior history....maybe someone topped it off with another type, etc..
I bought the car new and have never added anything to the radiator. Is ford G 05 yellow basically prestone? I was gonna get some motorcraft from the dealer but with my work schedule I'll never make it there.
No, Prestone is closer to Dex-Cool. It's not G-05.
