At work I take care of a 2006 Freightliner with the Cat C7 engine with the HEUI injection system. If I let the oil run past 10000km/6300mi, the engine codes for "unable to reach desired injection pressure", obviously from the oil shearing down. I have settled on a oil change interval between 8k km and 10k km.
Engine takes 24 l of fresh oil at oil + filter change. The filter is a big 2 litre filter. Cat filters are about $26 though I just bought ten of them on sale at 50% off, bringing the price down to $13 each. So far I have replaced the filter at every oil change.
Should I replace the filter at only every other oil change? Every other oil change works out to 20000 km/12600 mi. This large filter should easily handle 20k km. I don't feel comfortable taking the filter off and draining the old oil out of it and reinstalling it back on the engine. The filter is mounted base up and I would have to invert it to drain the oil and there is too much risk of unfiltered oil making its way into the filtered section of the oil filter.
Would the 2 l of old sheared oil remaining in the filter significantly degrade the 22 l of fresh oil?
