Originally Posted by billt460
Originally Posted by 92saturnsl2
When I got home, I look the tires over just for grins and my eyes caught the word INSIDE facing the OUTSIDE of the vehicle. These tires are non-directional asymmetric tread, so while there is no certain direction of rotation (you can swap tires side to side) the tires are marked INSIDE and OUTSIDE and should be mounted as such because the inside and outside of the tread are different.............,
so I take the car to a different tire shop nearby for help. They tell me that they see this ALL THE TIME on cars that come in, even pointed out how dangerous it can be, especially in the case of directional tires............. SUPER glad I checked the tires over, because this is something that could easily be missed and driven for a long time in a potentially unsafe condition. Anyone else ever experience a tire mounted incorrectly?
Tires are either directional, or non directional. If they are directional they will by marked with a rotation arrow, showing which way they are supposed to rotate. Not, "INSIDE" / "OUTSIDE". Your tires are non directional. They can be safely mounted either way. This is done all the time with red striped and white lettered tires today. A lot of people do not want the white letters or the stripe showing. So the tire center will ask which way you want them mounted, facing in or out. They are also non directional, and it is NOT "dangerous" to do this. And many times the tread pattern is slightly different on these tires as well.
The tires you purchased can also be rotated in a criss cross pattern, with the left front rotated to the right rear. Again SAFELY. If the tires are directional, again with an arrow showing the direction they should rotate, they can only be rotated front to back, while remaining on the same side, so they rotate in the same direction.
Think about it. Tires like yours could be all mounted "correctly", with "OUTSIDE" showing on every tire. But if they were directional you would have an unsafe condition if you criss crossed them on rotation. That is why the ARROW is used to signify rotational direction, and not "INSIDE / OUTSIDE". The second tire center you went to, that said you had a, "dangerous condition", is giving you false information in regard to your tires. Because again, they are non directional. So no such, "dangerous condition" can be achieved by how they are mounted.
The original tire center that put them on for you was giving you the correct information. With that said, they treated you poorly about it, and have now lost your business because of it. This falls under the classic saying, "The customer is always right........ Even if he isn't". Had they been more polite, and offered to switch them around, they would still have you as a customer. Apparently they felt you weren't worth that effort. But it doesn't change the fact the second place who changed them for you, handed you incorrect information. They were just nicer about it.
You are wrong. No matter where on the car you put these tires the tread pattern for water distribution or curb grip will always be the same. If you put them on wrong the pattern of tred would be wrong and could be dangerous especially if it is designed to push water out. Put the tire on backwards and then water gets pushed in so hydroplaning is a real concern.
