Quote:
I wouldn't take any one material/construction attribute of a tire or the way it's marketed as an indication that it will outperform another tire in wet weather.
The chemical composition of the tread compound dominates all other considerations in determining how well a properly sized and inflated tire will brake on wet pavement.
Quote:
A little research in what goes into wet traction shows that it's more than just about whether or not the nature of the tread compound is hydrophilic, hydrophobic, or somewhere in between.
Would you please share the source of your research?
Quote:
Siping certainly helps with wet weather traction, but is generally avoided in 3-season/summer tires due to its effect on dry steering response.
Siping can make a poorly designed tire brake better in the wet, but it pales in significance compared to the chemical make-up of the tread compound. The best wet-braking tires in the world are not heavily siped.
In the December 2006 issue of Car and Driver magazine, pages 124 to 126, the editors reported on their controlled test of a Goodyear three-season tire (Eagle F1 GS-D3) against a Goodyear all season tire (Eagle RS-A). (Car and Driver was using the Goodyear test facility, so presumably felt compelled to use the host's brand of tires.) From 60 mph, the GS-D3, which has no siping at all, stopped in 132 feet, while the heavily siped RS-A stopped in 155 feet, a 17 percent longer stopping distance. Twenty-three feet is approximately one and a half car lengths, and could be very significant if the edge of the washed-out bridge happens to fall within that last 23 feet of braking.
Quote:
Flexibility helps to keep more of the rubber in contact with the road. Many (possibly the vast majority) 3-season/summer tires are tuned for dry steering response at higher temperatures and with a less flexible compound. You can feel the compound is stiffer in many 3-season tires.
What are you claiming here? The
sidewall stiffness is what contributes the most to ride harshness or suppleness, and is a factor in steering response. But the sidewall is made of a different compound than the tread. Belts underneath the tread contribute to maintaining the
tread's geometric stability, and maintaining that geometry is generally considered a good thing for braking.
Far more important to the "stiffness" of the tire's interior construction, however, is the softness of the tread compound on the outside of the tire. There is a correlation (unfortunately) between short treadwear ratings and good braking, and between poor braking and long treadwear ratings. Because the main argument for all-season tires is economy (the vehicle owner in a area where it regularly snows would need a second set of winter tires -- usually mounted on a second set of wheels -- rather than running a single set of tires and wheels over the course of the year), the tire manufacturers cater to the economy-uber-alles all season tire target purchaser by making all season tires that generally have very high treadwear ratings, using tread compounds as hard as figurative diamonds. The tire companies could (and occasionally do) make all season tires with sensibly safe softer tread compounds, but that is confusing to the target market.
The tire designs with the best wet traction are all non-all-season designs. Most "summer" tires fall in that category. There_
are "dry-only" tires that_
do sacrifice a lot of wet traction for the last iota of dry traction, but -- contrary to your assertion -- they are a small minority of the "summer" tires on the market, not the majority.
Quote:
Good tread design goes a long way too. Bridgestone uses a "scalloped" tread block in the RE960AS which they claim helps improve wet weather traction.
The tread design affects resistance to hydroplaning. Except for hydroplaning, the best tread design for traction, even wet traction, is no tread design at all. There is a reason why racing cars, for which braking is very important, run racing "slicks." The reason racing cars have to change to treaded tires when it rains is that, at high speeds, hydroplaning is a serious problem. For those of us who do not race, hydroplaning is a much less serious problem. The most important contribution that tread design makes, however, is to marketing hype, as your comments illustrate.
Quote:
The nature of their tread compounds defies any single categorization.
Erm . . no. A tire engineer (such as occasional contributor here CapriRacer) could categorize the tread compound for each of the Bridgestone tires without difficulty. (There are, however, some "striped" tires, like the Goodyear ResponsEdge, that have an all season compound on one side of the tire and a three-season compound on the other side of the tire; I am not aware of any Bridgestone tires that use that technique.)
Quote:
Are there any 3-season tires that will outperform the RE960AS in wet weather? I'd think that's likely. I'm sure hydrophilic rubber goes a long way to improving wet weather traction, but there are likely other attributes of most 3-season tires (stiffer compound and lack of siping) that detract from wet weather traction too.
Hydrophilic compounds, used in all-season tires, tend to
detract from wet traction.
Quote:
You could probably come up with some killer flexible/hydrophilic/siped wet weather tire designed for low temps but not snow. However - it wouldn't neatly fit into the current tire marketing categories in North America. I certainly don't know where to find that in my 205/55R16 size with at least a V speed rating.
If you really searching for such a tire, you may want to check out the Nokian NR series, optimized for the prevailing nonwinter conditions around Helsinki.
