Hello, since this is the tire section I will reach out to you folks.
I read that the dot on the outside of the tire either red or yellow signifies the light side of the tire. With that being said,
I was told that the Dot should always be close to the wheel stem.
This is a brand new Toyota RAV4 and you can see that the dot is close to the stem. Is there any real significance to that statement, being that the closer you balance the natural tire with the wheel the less weight you will need.
During my sport bike days, that was a significant must to reduce the amount of lead weight. I'm just wondering if this holds true to wheel and tire manufacturers as they put these dots on them for a reason. Any input would be great. I also was told at the local tire stores; and this is with a deer in the headlight kind of look! that, "oh don't worry about it" , it doesn't mean anything.
Thanks in advance for any input.
