tdi-rick,
In the early days of radial tires, cross rotation patterns could lead to premature failure. However, modern radial tires do not suffer from those problems and it is actually beneficial to cross rotate - prevention of irregular wear.
Pee Wee,
Why Toyota doesn't recommend cross rotation is a mystery, especially for 4X4's - perhaps they are stuck in the 1970's - but when in doubt, follow the manual.
Everyone else,
Just so we are clear - directional tires will have an arrow on the side showing the proper direction of rotation. This means rotation on the same side - front to rear. However, no arrow - not directional.
Tires that have the words "This Side Out" are asymetrical, and it doesn't matter which direction they rotate. This means any rotation pattern works.
If the tires have both - then they are both asymetrical and directional - and the rotation pattern is front to rear.
Unless you have different tire sizes front to rear.
Hope this helps.
[ June 27, 2004, 08:07 AM: Message edited by: CapriRacer ]
