They have always given us problems, especially when the temperature drops suddenly.
Plate inside the door says 34 so I check and the tires are at 34. Spare is filled to spec as well.
Light comes in, flashes and then stays on after I start the car. From my research that means the sensor is failing to send a signal. If it didn't flash before staying on, that means tire pressure is low.
Called Discount Tire, they said sensors are $60 each.
Are there any other recommended alternatives?
I would assume if I bought online that not only would the shop have to install them but programming would have to be done as well to the new sensor?
