tire preservative, for storage
I read some of the previous posts, but still have questions. I want to protect trailer and other tires with air and hard rubber without air in them. sitting outside year round, mostly shaded. Is there something I can buy at Walmart, or Menards etc, that I can just spray on and leave?? I have some carts and stuff like that that the weather won't hurt, except for the rubber parts.
The most important thing is to keep them out of sunlight.
So if I would keep under the deck where the sun can't get to, I don't need any coating, and the rain and snow etc won't hurt them any more than if they were in a cheap shed?
Keep them jacked up off the ground if possible to prevent flat spots
Barry's take: https://www.barrystiretech.com/tirestorage.html
Short Version:
  • Store tires in a cool, dark place away from sources of heat and ozone (furnaces, electric motors)
  • Store tires unloaded
    • Not on the vehicle unless the vehicle is lifted off the ground
  • If the tires are on a vehicle that is being stored, inflate them 50% more than normal
    • Yes, the tire will be able to handle it. Tires don't burst until many times the max pressure listed on the sidewall
  • It's OK to stack them
    • Not too high. 4 high at most.
    • But Not on or in anything that is harmful - for example: oil
    • And NOTon something that shouldn't be stained. That includes concrete/tiled floors.
      • Even a layer of paper is not enough to prevent a stain.
    • If the tires have white sidewalls or raised white letters, store them white to white
      • But be careful as white rubber can be stained by black rubber.
  • If mounted, it's OK to store them at normal pressure.
    • Don't do anything about inflation pressure until you reinstall them.
    • No need to deflate them as it doesn't have much affect on anything.
    • Don't deflate them if you're going to stack them.
      • Unless you are going to use spacers so the stacking is wheel to wheel, rather than tire to tire.
  • Avoid petroleum products
  • Tires can leave a stain. Avoid surfaces that shouldn't be stained.
  • If the tires are Extreme Summer Performance or racing tires, do NOT store them where the temperature gets below 40°F (5°C).
