did you let most of the air out of the tire?
When you pulled out the object try to determine the angle it was in tire.
The reamer is like a file it does not matter if you twist.
If hole was extremely tiny you may need to drill it.
When inserting the plug you do need to go straight in.
OTOH if the tire is worn out just replace it???
