Tire leak
Minnesota
In 2016 I had a set of Michelins mounted on a new set of Honda alloy wheels. I've always had one tire that would leak 1-2 psi a week. Kind of annoying but not a huge issue to top off.
Well today I sprayed the wheel and tire down with soapy water to find the leak. Found a small leak on the rear bead. I broke the bead and found that there was a sticker on the tire right where it meets the wheel. The sticker was exactly where the leak was. So I removed the sticker, aired the tire back up and the leak was gone.
How dumb is it to put a sticker right there? That little sticker caused me a lot of grief. The tire shop should have removed it. Anyone else have a leak from this sticker?
Yeah I thought it was weird a 3 year old wheel that has never seen salt or snow would have a bead sealing issue. Definitely a bizarre issue. I'm assuming the other 3 tires also have a sticker on them but they aren't leaking.
