The front wheel on my motorcycle was losing pressure, maybe 2-3 psi per week when the weather was warmer, but now that its cold it started losing a lot faster, 10+ psi overnight. I found its leaking at the bead, from one particular spot, so I dismounted the tire and I see there is some damage from the tire spoons used to mount/dismount tires. What would be the best way to polish these out? Manual sand paper, or grinder with a particular type of wheel?
