Hello!
I have changed a few tires myself now (by hand and with the Rabaconda machine ) and am gaining an impression that dismounting tires to use again is a bad practice since bead damage is very likely: especially on a motorcycle.
Any tire experts out there? If the bead’s primary role to seal to the tire in a tubeless application, would a knick from a spoon like this be any cause of concern IF it seals well? In this particular case the rest of the bead is absolutely mint, this was the first bite in the dismount to get up and over the machines duckhead. (Tire was warm, soap and water and spoon was greased up)
What would be the failure mode? Of it doesn’t leak, what would be the worry?
If there is no damage to cord or fabric and outer rubber alone is damaged, is there any cause for alarm? Is this purely superficial ? How can one tell if it’s time to trash due to damage?
Long story short, I got the machine to change to and from street to off-road biased tires and am wondering if remounting motorcycle tires is a poor practice…. Or maybe I just suck : )
P.s. the photo with the pic shows the max depth… stuck it in as far and as deep it would go. Appears to be very superficial but I am still sweating reusing the tire.
Thanks!
Thanks!
