Tire gauge reads in tenths
Northeast Nebraska
Since I left one of my cheap digital gauges in a car I sold I needed another one so I purchase this one.
https://www.amazon.com/gp/product/B073V74T23/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
When it came I got out my Longacre to see how accurate it was and noticed it read to a tenth of a pound. What application would require adjusting tire pressure in tenths? And if you were that picky would you trust a $10 gauge?
It is accurate and was never more than 3/10 difference than the Longacre. It is also easier to use than the Accutire MS-4021B as far as getting it on the valve without losing any air. It also has a built in light that may come in handy.
Originally Posted by Rand
does it actually read to the .1 or the .5 lb?
I picked up one that looks nearly identical from HD last week for $6. It only reads to the nearest 0.5 PSI.
Originally Posted by Duffyjr
What application would require adjusting tire pressure in tenths?.
ATV's..... Rock Crawlers.... other "High Floatation" tires
Yes sir. The first tire I checked was 32.03 while the longacre was 32.5.
Amazon reviews looked very good, must be a decent gauge.
Ya mine calls for 2.2 lbs. Thankfully its not that critical.
2.2 lbs or 2.2 bar?
2.2 lbs or 2.2 bar?
Lbs
