Look at the other side of the tire. There's no date code there. Sometimes the date code is only stamped on one side, and that appears to be the case here.
Check the other tires, before you go crawling underneath. You might get lucky...
You need something that ends with a number that has 4 numbers.... such as 1621, which would be the 16th week of 2021.
