92saturnsl2
Originally Posted By: Kawiguy454
Looks to me like the tire got pinched between whatever caused the rim to bend. You see that a lot on off-road tires with low pressure. This is why when I'm traveling long distance I keep tires inflated to the high end of their spec. IMO 32 psi is not enough air if you hit anything substantial at highway speed. And the lower the tires profile the less margin you have.
I actually aired tires up to 38 front / 36 rear before leaving-- I do just as you mentioned and air the tires up a few PSI over OE spec, if for nothing more than MPG improvement. Whatever it was we hit, a tire blowout seems unavoidable given the amount of rim damage. I'm just lucky to have not damaged anything in the rear suspension, so far as I can tell.
