I have a set of Michelin X Radials from Sam's Club on my '07 T&C. They have right at 30k miles on them, and all tires are right close to 7/32" of tread depth. The original weights on the wheels from the factory were coated (to protect the wheels I guess), but the weights I've been getting from Sam's Club are not coated, and some have nicked the wheels (either the weights, or them clumsily taking them on and off). So I switched to them using the tape weights on inside of the wheel (not the inner lip, but the inside curve of the wheel, like flangeless wheels do). Ever since then, it seems like they can't quite get the tires balanced perfectly. And everytime I take it back, the weights move around some, indicating that the balance might keep changing. I had this experience before on a different van (with the weights moving around after each balance), but with one tire, and the problem was something internal to the tire. After that one tire was replaced, everything was fine. But I can't narrow this down to any one tire. It just seems like bad balancing jobs. The OEM tires (Bridgestone Turanza EL42) were glass smooth, so I don't suspect any bad wheels, etc.
I figure I have a few options:
1) I could take it back and have them re-balance, and keep using the tape weights. I may not get anywhere with this, because I've been doing this before.
2) I could take it back and have them use conventional clip-on weights. When they installed the tires, they got them balanced good this way.
3) I could take the tires to a Hunter GSP9700 machine to have them force balanced, at my expense. This is the only way I "proved" that the one tire I mentioned earlier was bad, and the retailer (not Sam's Club) replaced it for free. They even gave me my money back for the force balance, at my request.
I think I'm leaning towards option #2, but let me ask a few questions if I may:
A) Is there any functional difference in a tape weight and a clip-on weight? I think I read before that you'd need slightly more weight if using tape weights, because the weight would have less influence on balance being further inboard as compared with a clip-on weight.
B) Those wheels without flanges, that force you to use tape weights, are they built to a different specification, a higher tolerance, etc, which makes tape weights any more successful with those types of wheels?
C) My T&C's wheels do have the lip flanges, and they're "supposed" to use clip-on weights. Will I have more success (will I get a better balance?) if I use clip-on weights vs. tape weights?
Many thanks for your replies.
