N Nukeman7 Joined Sep 23, 2006 Messages 3,883 Location 757 Virginia, USA Apr 22, 2025 #21 brages said: I thought the tensioner side WAS the slack side (the tensioner takes up the slack when you pull the pin) Click to expand... You are correct...he meant the red side is the tensioned side (i.e, taut before releasing the hydraulic tensioner).
The Critic Joined Aug 30, 2004 Messages 35,392 Location CA Apr 22, 2025 #22 brages said: I thought the tensioner side WAS the slack side (the tensioner takes up the slack when you pull the pin) Click to expand... Tension* side, I just made the edit. Thanks.
