- Joined
- Mar 19, 2022
- Messages
- 876
SOC and temp is more of a function of the charging system and parasitic load and time since the vehicle was last running and for how long. Than a battery health indicator.
Sorry to hear this. NAPA Legends have always been good for me that's why I recommend them.Yesterday I took a different battery to the FLN(NAPA)APS to have it tested and was told their battery tester was broken and the counter guy didn't offer when it would be fixed or replaced. And NAPA is the only place I feel like they kinda know some things.
I'd assume there is "smart" charging system on that, so it probably shuts the alternator off fairly often, and you might have just pulled in and stopped as it had been running off the battery for a while?I just did a 200 mile highway trip yesterday in the 2021 GMC with the 6.6 gas engine (empty) and decided to check the resting voltage of the battery this morning and it's 12.54 volts. The truck is used to tow the travel trailer all over the country and I don't want to deal with a no-start - replace battery deal out in a remote campground somewhere. The battery is original and is a group 94, 720 CCA and GMC lists a 94 and a 48 as replacements. I have a decent Klein multimeter and tested directly from the terminals so that's a good number. Also would an AGM equivalent like an H6 be a good upgrade? My standard SOP with batteries has been replace it when the first slow crank is noticed but maybe not in this useage. I've been following the ongoing "no more AGM" thread and as usual varying thoughts about AGM vs flooded.
So, replace almost 5 YO battery now and go to AGM or replace with another flooded L/A?
I’m glad you’re enjoying your new tool! You’ll notice on a new replacement battery in good health the CCA will possibly read higher than manufacturer specifications. I purchased a 525CCA it read 538 after putting it on a charger it read 551CCA. If you have a charger and your new battery isn’t topped off I’d recommend topping it off.On the recommendation of @DCDG I ordered a battery tester and it came today and I got this so it looks like a new battery is going in before we go anywhere.
This is the OEM battery: Interesting the replacement is 765 CCA.
Great tester. I got one a few months ago. It cost me money however. I ended up buying two batteries and a third one is in the near future....On the recommendation of @DCDG I ordered a battery tester and it came today and I got this so it looks like a new battery is going in before we go anywhere.
You're welcomeThis battery is almost 5 years old not unhappy with it. Maybe I'll put the Pro-Logix on it and see what it does. Thanks for the rec on the tester.
FloodedI just did a 200 mile highway trip yesterday in the 2021 GMC with the 6.6 gas engine (empty) and decided to check the resting voltage of the battery this morning and it's 12.54 volts. The truck is used to tow the travel trailer all over the country and I don't want to deal with a no-start - replace battery deal out in a remote campground somewhere. The battery is original and is a group 94, 720 CCA and GMC lists a 94 and a 48 as replacements. I have a decent Klein multimeter and tested directly from the terminals so that's a good number. Also would an AGM equivalent like an H6 be a good upgrade? My standard SOP with batteries has been replace it when the first slow crank is noticed but maybe not in this useage. I've been following the ongoing "no more AGM" thread and as usual varying thoughts about AGM vs flooded.
I know you did all you can to revive the battery one last thing go out a 30 min drive and retest I am curious what it'll read. I charged my battery the charger said full when I checked it it did read 97% as well went for a drive come back retested and had 100% charge. health went back up again my battery was new and healthier to start off with. But if you got a half hour to spare plus a retest.I charged it overnight at 10A with the smart charger and still got this.
