Originally Posted By: qship1996
wrap pully with an old belt to protect it and then wrap a chain wrench around it, wedged against an unmovable object{frame of car or other sturdy object in the srea} then use a torque wrench to tighten to specs{ I had to tighten mine to 270ft/lb this way-easy}
I have seen an old timer "make" a strap wrench using a length of old serpentine belt, and use that to hold the pulley while he tightened the crank bolt.
