Thunderbolt display connections
JHZR2
Staff member
New Jersey
Can anyone confirm if it is possible to utilize in alternative display connector on a display that utilizes Thunderbolt? Looking at high-end displays it appears that the Apple thunderbolt display is by far the best deal in that range. The equivalent Samsung, s27b970D, which is a beautiful monitor is $200 More it seems.
But there seems to be a lot of conflicting information as to whether thunderbolt, which apparently utilizes the same connector as mini display port, just with different functionality, can be used with an adapter to only serve as a display port or VGA interface.
For the application I'm looking at I would not be interested in using the WebCam speakers or anything else like that, all I would need is for it to serve as a display. But similar reports seem to conflict indicating that thunderbolt is a different bus and therefore isn't compatible. Any ideas? I may not have been searching well enough, but it seems like there is a lot of conflict.
They might "work", as in display an image, but resolution and or framerate will be decreased, may or may not be noticeable. Also consider the thunderbolt prolly operates at higher voltage and frequency, so it might fry the adapter after prolonged use. But it might work until an official adapter is released by apple or monoprice.com.
Short answer No
People are trying to use HDMI to Thunderbolt cables that were not designed for this. Those work fine when the source is active (system) Thunderbolt to an HDMI display but do not work in reverse
There are some active adapters surfacing but I would not be an early adopter. You may want to pursue the previous 27" Apple display
