Throttle body cleaning - will make your motor hum like new.
That's funny, because I just cleaned and greased mine plus I checked the electrolyte level. And I'm ashamed to say the level was neglected, as it was just barely 1/4 inch above the plates. Good one!quote:
Originally posted by CoosBayDave:
The things mentioned above are all good, to this I would add cleaning the battery connections. When I lifted the plastic cover on mine I found a ball of corrosion.
So only DOT 3 Fluid should be used in ABS brakes? what about that Valvoline Synthetic DOT 3-4 Compatible fluid? I use it in my motorcycle and it has very High wet and dry boiling points but if you are saying you see a problem in using it with ABS, let me know why??? becuase I was going to flush my OEM fluid with this stuff when it warms up outside.quote:
Originally posted by alreadygone:
As a Automotive Service Professional, I'd like to see more customers do Brake fluid drain/refills, but it's still so rare that many of my customers would want to "whup ma arse" for pushing a ripoff service that their pa never done!
Am going to list a few pertinent points;
Some of the major auto manufacturers still don't recommend fluid changes.
IMO brake fluid should be changed occasionally just because it's hygroscopic (attracts moisture).
Anyone who's ever rebuild a master cylinder or wheel cylinder has seen the NASTY black gunk that accumulates in the low spots of a car's brake system.
In ABS brake systems, fluid should only be flushed in direction of wheels to keep from causing abovementioned gunk from plugging valves in ABS mechanism.
Use only approved (usually dot 3) fluid in system or you will cause more problems than you fix!
Bob
