eh, theres honestly not even enough room in there to get a second hand on the hose to hold a different angle or anything while trying to tighten down. i feel like ive done just about all the wiggling i can do in the tight spaceThose things can be finicky. Any chance you can move the line or the rack to get a bit more clearance? Perhaps some wiggling to needs to take place in order to get the fitting centered.
Line it up as best you can, turn backwards until you hear a click and then turn clockwise. No tools until its threaded in a few turns. Unlikely but not impossible to cross thread if using only your hands.The line is clearly about to be cross threaded in the photo. It’s not square to the pump fitting. You’ve got to get the threaded part of the line squared up. Pressure, perhaps even a bit of bending, it until its perfectly square then it should thread by hand. Once threaded, a crow’s foot from the top or quality stubby, perhaps.
I've really never felt this useless before, I spent 8 hours just slowly trying to adjust and readjust but never got it to thread properly... i have never been so defeated. thread looks good on both female and male ends... i guess i try again in the morningLine it up as best you can, turn backwards until you hear a click and then turn clockwise. No tools until its threaded in a few turns. Unlikely but not impossible to cross thread if using only your hands.
The drain plugs in my old Mercruiser 5.7L engine were far down on the sides of the engine. No real way to see, had to do it all by feel. Including at one point using a NPT tap to clean up the threads.
In this case it was brass plug going into cast iron block.
appreciate the words of encouragement. Ive been doing it mostly by feel to be honest, once i get my hand up in there, theres not a room to see much unless i position my phone to catch it and view from the screen as im turning which is a pain. i will say, there was a few times i felt like i was close, more tension as i was turning like it was beginning to sit but whenever i got that feeling the nut would pop off and id have to restart. I got myself in a little over my head i guess, ill hope for more luck in the morning, i know once it finally sits in ill be doing victory laps around the neighborhoodAs others said you need to gently thread it by hand for a few turns and then use a crows foot to tighten it. When you think your nut is threaded properly it's probably off 5 degrees or so. Maybe you should close your eyes and try to thread it by feel a few threads doing it gently.
Power steering line repairs are usually the biggest pain in the butt since the areas are so tight. You wish you had as many arms as an octopus in order to do what you need. Rest up and do it the next day. I've been there many times.
its got some wiggle to it already, i feel like bending it is extreme, i feel like its just a matter of finding the right angle and a lil bit of luck. i just removed the old pump from the same line, and with there being movement im just VERY nervous to get too aggressive with it and get to some point of no return.As others have said, it's leaning to the right in this picture.
That tubing will bend. Go in there with some long pliers and persuade it a little so the line is sticking straight up. Then try again.
Whatever you do, don't force it in. You'll just FUBAR it up. Slow and steady wins the race. If you can't get it at first, take a break if you can and come back an hour later and do it. You'll get it done.appreciate the words of encouragement. Ive been doing it mostly by feel to be honest, once i get my hand up in there, theres not a room to see much unless i position my phone to catch it and view from the screen as im turning which is a pain. i will say, there was a few times i felt like i was close, more tension as i was turning like it was beginning to sit but whenever i got that feeling the nut would pop off and id have to restart. I got myself in a little over my head i guess, ill hope for more luck in the morning, i know once it finally sits in ill be doing victory laps around the neighborhood
