4wd
$50 site donor 2026
GTG’s have lots of support equipment that needs regulated temperature control … Heat trace load alone often surprised folks who have not worked in countries that end in a, or eh?
They already have approval to upgrade South Texas Project … hope this helps move that forward.Texas' unique "power island" concept has displayed its weakness - time for some regional interconnections to avoid future fiascos.
Two natural gas combustion turbines with one steam turbine. Something like about 120 from each combustion turbine and 80 from the steam turbine. About 5% went to co-generation so only about 300 megawatts on the grid.Makes perfect sense, I was thinking steam plant, but you are talking GT.
The biggest snowplow I have seen working was a CAT 988 in a far away land …
I hear Panama is nice. Going to check it out soon.Moved here after 17 long years in Wyoming, for the purpose of getting away from this kind of b.s. weather. Sad to say, even -40 in Gillette, WY never crippled the infrastructure like 0 appears to in Dallas. ERCOT, pull your pants up.
I guess I didn't go far enough south. How's the real estate market in Brazil? Or maybe something right on the equator?
I wonder if that chopper has an internal combustion engine. LOL.Obligatory:
I disagree. ERCOT can only do so much within a budget.Texas' unique "power island" concept has displayed its weakness - time for some regional interconnections to avoid future fiascos.
For example, normal building codes assure new homes to be built structurally strong enough to survive 120 mph winds. Could every single home be built to withstand 200mph winds? Yes, but at extreme costs. ERCOT, like other utilities prep enough to cover probably 99.9% of the conditions expected. This deep cold is a very rare event for Texas, its the 0.1% that is stressing the system.
This is going to pass soon and Texas will be just fine.
Just read one STP reactor lost 1300 MW capacity with cooling water issues … doubt it’s winterized enough …This is true. I think the main concern by some I've seen is that Texas has spent north of $70 billion on wind. That would have built Vogtle at least 3x (assuming costs for subsequent plants would be cheaper). That's 7,500MW of firm capacity vs the current 30,000MW of flamboyantly unreliable capacity and its gas-backing. While that looks like a huge rift, consider that wind was at 800MW this morning and showed up at 1,600MW when it was expected to be 6,500. The nukes would have been 7,500MW, meaning reliance on gas would have been 7,500MW less.
I hope this event spurs some re-evaluation of capacity value vs just capacity cost. Wind + gas are cheap but that combination has exposed its vulnerabilities during this event and if the trend continues, will be even worse in the future.
Yup, that's Rod's commentary that I was thinking of when I wrote it, lol.
The trip resulted from a loss of feedwater attributed to a cold weather-related failure of a pressure sensing lines to the feedwater pumps, causing a false signal, which in turn, caused the feedwater pump to trip.
just saw on the local news that the record low for Colorado was in a small town in northwest Colorado in 1985.
-61 F
Not a typo thats minus 61.
Just got power back, was 36 hours with no power. Low of 14°F both Monday and Tuesday. High was 17°F on Monday, is up to 34°F right now.
Luckily I have a gas fireplace, but that is not really designed for heat, more for appearance.
Temp inside house got down to 43° F inside with the fireplace going the whole time, back rooms were in the 30's. Not looking forward to that gas bill for sure.
Never lost water (master shower quit flowing, not sure why, not an exterior pipe, but have PEX, so not worried about breaking pipes).
Had no internet and phones had no signal. Hard to be totally out of touch. I only had occasional texts going through as well.
Roads are starting to thaw as well, but my driveway is solid ice now.
I praise the grip of ice-cleats that I use on my shoes and boots when there is ice on the ground. When you use them it is like being glued to the ground even when there is a 1/4 inch or more of ice covering everything. The hospitals her in Pittsburgh PA get patients with broken bones from falls on ice every time we get ice on the ground, and people here are use to ice and snow ever winter. If you do not have ice-cleats you are better off staying at home until it melts. Broken bones can be a painful thing and a broke hip or neck of the femur can be life threatening and may even cause death. Falls on ice are nothing to fool with, and they happen very fast once you star slipping. And the older you are the worse the damage and the slower you heal. I have seen it happen too many times to try to walk outside without ice-cleats when there may be ice hidden under the snow. I keep one set of cleats in the car and two sets in the house.
So my warning to you in the south who are not use to ice, is if you do not have ice-cleats just stay home until it melts. Seriously, I am not kidding, especially if you ain't no 21 year old any more.
Haven't seen this here in my lifetime. Nothing to those up north but a total shutdown for us. Tonight is to be 0º F +/-
Feb. 15 when you posted this, the temperature in Dallas was colder than we had in Toronto Canada.Haven't seen this here in my lifetime. Nothing to those up north but a total shutdown for us. Tonight is to be 0º F +/-
