My drag only 388 small block chevy has to much oil pressure and keeps blowing oil from the back of the intake and bottom of the distributor. It's a 12.5:1 motor that runs on E85 with a 5500 stall that I shift at 7000 and pass through the traps at about 7500. The cam is a solid lifter flat tappet and I have been using Rotella T or Scheaffers 15W40 in it. The block has a tall fill and I still have difficulty keeping the motor warm. The oil pressure is at 80 pounds at a 1200 RPM idle and off the scale when the rpm comes up. Once I get the motor up to temp in the shop after running it for 40 minutes or so it will idle at 30 pounds and move to 80 when rev'd up. Problem is that the car never gets ran enough at the track to heat the oil up enough for the pressure to drop. I'm thinking of stepping back to a 30 or maybe even a 20 weight in it. Am I barking up the right tree here?
