Why? It does everything I need it to do just fine.Get a new computer. That thing is old!
It's a firmware issue. Samsung has issues updated firmware that will prevent this problem.Stay away from Samsung. Their SSDs are prematurely wearing out according to SMART data, OEMs are dropping them.
https://arstechnica.com/gadgets/202...sds-after-users-report-abnormal-health-drops/
Then I wouldn't trust anything because they have all had issues over the yearsI wouldn't trust Samsung after this
SSDs are always best backed up by HDDs IMHO, you can at least recover an HDD by a recovery company whereas an SSD is impossible for the layperson.
I don't trust them SSDs overall which is why I backup to HDD, but if OEMs are dropping them, well that's a big sign to me.Then I wouldn't trust anything because they have all had issues over the years
They are dropping the 990 not all Samsung. We use SSDs to build software with reads a writes lots of files when doing builds and I have never had one fail yet. We have had a few start to throw errors and we replace them before they get bad.I don't trust them SSDs overall which is why I backup to HDD, but if OEMs are dropping them, well that's a big sign to me.
pagefile is a system file which cannot/should not be deleted. It is like an overflow virtual RAM should your computer run out of physical RAM.
With that said, you can modify how much page file your system should use or not use it at all if you have plenty of physical RAM.
https://smallbusiness.chron.com/reduce-pagefilesys-size-53940.html
Problem with that is you bring over years and years of garbage. Every so often, whether its Windows, macOS, iOS, or Android, I wipe the drive/storage and "start over". I have important stuff saved.it would be identical upon startup. Only difference MORE SPACE!!
Wait until you have a hard drive puke and you lose everything. I'm not a fan of enormous storage, preferring multiple, smaller ones.If he didn't need it it wouldn't be saved. Upgrade to a bigger drive, keep everything! easy..
Something you're going to run into more and more often.That's what I did in 2016 when I installed the current SSD, but when I go to the Acronis site now, it doesn't show Windows 7 compatibility.
Don't bother with this. You have quite a lot of RAM as I recall so your swap file isn't something to worry about nowadays. It's also "dynamic" in size, growing or shrinking as needed.Says 13.4 GB being used and I have 32 GB installed.
Please step away from the computer and talk to someone who knows what they are doing!Why can't I open this file named pagefile.sys to see what's in it or what its for so maybe I can delete it?
Only have 80 GB of important stuff in photos and documents I'd hate to loose, and those are in 4 separate folders for easy access, plus the Favorites list in Windows. What's wrong with bringing over years of garbage when there is twice the space?Problem with that is you bring over years and years of garbage. Every so often, whether its Windows, macOS, iOS, or Android, I wipe the drive/storage and "start over". I have important stuff saved.
Hall?Please step away from the computer and talk to someone who knows what they are doing!
This random system file deleting is just a recipe for a disaster.
How long did you wait ?Why can't I open this file named pagefile.sys to see what's in it or what its for so maybe I can delete it?
Look again. You have 'only' 16 GB installed and something running on that system is using almost all of it. That's not normal, nor is a 32 GB pagefile.
I didn't wait at all. The popup says it CAN'T be opened because of internet security. So much for W7 being insecure.How long did you wait ?
Personally, I've never opened a 33gb file but I'd guess it might take a while !
