So I've got a nineties F250 that I'm thinking about removing the factory oil cooler from. It's got the 5.8l small block and has a water to oil heat exchanger that I think came as part of a towing package. A towing package on this truck just seems kind of silly as the 5.8 is way too under powered to tow much anyway. The cooler is the type with an adapter that's sandwiched between the block and the oil filter.
I have a few reasons for considering taking it off. One is that the truck mostly sees short, back roads trips so I wonder if it does more harm than good by keeping the oil too cool. The hardest this truck ever works is occasionally hauling a 2500lb camper on hunting and fishing trips. Another reason I was thinking about removing it was so I could use up my stash of FL1a filters. The main reason I want to get rid of it is that I'm replacing all the hoses and the hose for the cooler is an extra fifty bucks. (Yeah, I'm a tightwad).
What do you all think?
