Originally Posted By: Shannow
Originally Posted By: CATERHAM
So the lightest oil that
still provides 60 psi of OP at maximum oil temp's represents your optimum operational viscosity.
While I agree with your assertion that the oil backpressure demonstrates the bearing's operation as a functional viscometer, it does not, in any way correlate with the optimum viscosity for successful bearing operation...they are two different sets of parameters.
Is that not a contradictory statement?
If a certain minimum oil back-pressure represents the minimum optimum viscosity for an engine how does that not "correlate with the optimum viscosity for sucessfull bearing operation"?
If this is accomplished using a 2.6cP 20wt oil any oil heavier than this will provide higher oil back pressure and reduced oil flow up to the by-pass point.
Positive displacement pumps don't work that way...they shift stuff, and withing very broad parameters (and an engine oil is pretty narrow in the scheme of things), the same amount of stuff per revolution.
Increased backpressure doesn't materially affect flow.
Yes that is how positive displacement oil pumps work in theory but in practice to put it simply, they leak. As the oil back-pressure increases so does the rate of oil pump leakage in the system. That is why heavier oil pumps more slowly through an engine than light oil. Of course if the oil so heavy that the oil pump by-pass valve is activated the oil flow through an engine will be decreased at an even faster rate.
This was discussed in detail in the following thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2732602&page=2
