OK, I got more cold than was expected.
-27F at 6:30 this morning. Definitely the coldest temperature I've ever experienced.
To sum it up, the Camaro started, but my smart phone didn't, so I was unable to get video of the gauges on startup. Apparently the smart phone turns itself off below a certain temperature.
Some obervations:
When I turned the ignition on, the voltmeter barely got up to 12V.
When I cranked the engine, it did so very slowly, but fired in about 2 seconds, and immediately went to 1500 rpm high idle. It stayed there for about 15 seconds, then dropped to a normal idle.
It took noticeable effort to pull the shifter from 1st gear to neutral, and the clutch pedal was also a bit stiff.
The voltmeter was almost into the red and was charging at ~16 volts.
No belt squeals.
The power steering pump made loud cavitation noises for the couple of minutes that I stayed with it. I watched the oil pressure gauge for a couple of minutes to be sure that the pressure stayed stable. It would not go over 30 psi if I gently revved the engine to 1500 rpm, and it was a stable 20 psi at idle.
Then I went inside, and had breakfast for about 10 minutes while the car warmed up.
When I started out for work, it felt like the shock absorbers had been replaced with steel bars, the ride was so stiff. I definitely drove easy for the first few miles and took pains to avoid all the potholes I could.
The steering was higher effort than normal, but the power steering pump cavitation noise was gone by the time I came out from breakfast.
Piston slap at idle was not as loud as other cold starts that I can remember using other oils. This PU/PUE blend seems to do pretty well for piston slap, especially compared to GC.
Coolant temperature was up to about 130F when I came out from breakfast.
My morning drive to work takes about 45 minutes, and it took about 40 of those for the passenger compartment to heat up enough to be comfortable.
