Gene K
For one thing, when this forum started (and you were here pretty early), there were major differences between oils (brand, weight, dino, blend, synthetic, "fake" synthetic" etc...) and an extended oil change was still 6,000 miles for many.
Today's oils are just so much better, and it is to the point so long as the oil and filter are changed on a regular interval with an appropriate viscosity, you will not have an oil related problem with the engine.
Yes, some do obsess with which oil, which weight, what interval, which filter. And with some motors there may be some small differences (mostly in interval length), but over all, nothing to worry about.
After a few years here, most come to realize there really is not much difference between oils, and regular changes are what matter more.
I have never been stuck on any oil.
If one of my vehicles gets more than 2 changes with the same brand and weight oil it is because I got a great deal on a bunch of oil.
My Santa Fe is on its 4th fill of Pennzoil Platinum 10w-30, just because I got it for qt.
With all the 5w-30 Rotella Truck I have in my stash (like 40 qts?), it will be a common oil for a year or so in my fleet, but once that stash is gone, I will switch to whatever synthetic I can get for the lowest price (Supertech, Quaker State, Havoline, Mobil on rebate, etc, I am not picky) and just don't worry about what oil is in the crankcase anymore.
I don't think it makes a real difference at moderate service intervals. My little sister's 140,000 mi '98 GM 2.4 Ecotec shows no sign of timing chain or oil consumption issues with 8,000-10,000 mi, 90% City OCI with standard GM Conventional, then Dexos 1 and finally Dexos 1.2 bulk its entire life. Now if you were going 15,000-20,000 like the European's it might need a more robust formulation.
