Originally Posted By: mechtech2
Electrical components can fail when hot.
This usually is ignition, but can be a relay for fuel.
If you told them that the problem was when it got hot, they should not just have performed tests when the car was running right. They should have duplicated the bad conditions.
I wasn't impressed with Pep Boys' inspection. From what I saw, they just let it ran and idle for 2 hrs on a cool day. Like most mechanics nowadays, they are usually only good at replacing stuffs instead of finding the right problem the first time.
I did drive to and from work today as well to the bank. The drive back home was a little nervous as I didn't know if and when it will cut out. But it ran all the way home with only 5 mins stop to get gas. I am trying to keep the tank full each day.
