The most reliable car I have ever owned was my.......
2005 4.6 Ford Crown Victoria. Was a former rental. Bought it with 25K miles and sold it with 300K miles. Only needed Water pump and Accumulator for the a/c. All the rest was plain old regular maintenance.
There will never be a low maintenance vehicle like that ever again. It took the pounding of the nasty pot holed streets of NYC like a champ. When I finally sold it everything worked perfectly.
2003 Jetta TDI GLS 5MT. A big spend at the time, $5900 and 220k miles. We put many years on it and never had a problem. Took it to over 310k, sold for 4k. So cheap for how much use we got out of it and55 mpg road trips was a novelty. Ended up hearing from the new owner later, still chugging along in the 400,000s.
Runner up, the replacement to Tdi, a 2014 Accord sport 6MT. It did need a warranty starter replacement. One flaw in 70k miles isnt bad.
Probably my '04 Odyssey. It's one of the vehicles you just turn the key and start driving and don't give it a second thought. We still drive it across country. I think in the last 7-8 years I've owned it, I've replaced a coil and a power window regulator, cost was less than $50 combined.
So reliable, yes. However the blue paint had a recall and naturally ours didn't start peeling until after the recall expired. So it's starting to look bad enough that we're getting rid of it for that reason only.
I used to never keep cars long enough, but the two newer vehicles in my signature have been very reliable (the Jeep too, but I don't put many miles on it).
2013 Ram 5.7 is at about 127k with nothing but a water pump replaced.
2016 BMW 740i is at about 80k (my wife drives it most of the time...) with nothing so far.
Whoever said it above is correct--most cars will be great with proper preventative maintenance. The kicker (and the $$$) is how you define "preventative maintenance."
I had a 2001 Taurus that made it to over 215k. I think I had it towed 3 times, once each for the springs breaking, first the rears broke, then the front. The front was on me though because that happened after the rears did and I knew it was just a matter of time before the fronts did, but I took too long and they broke on me. The 3rd time was when a coolant hose went and the ground was covered in coolant. Had it for 12 years.
I'm doing better on my 2008 Mercedes E-350 and 2011 E-350, both haven't had to be towed yet, but still lots of maintenance to them. Only 6 years on 2008 so it could still be early.
My parents 2004 Taurus with the Duratec is over 375,000. Still running like a champ and doing a 80-100 mile commute every day. There’s a reason that the duratec foundation is still around today. Sticking with chains when everyone else wanted timing belts I believe is what made these things so reliable.
No one ever wanted timing belts. It was just cheaper for the manufacturers. Like how the Taurus still had drum brakes. Just slightly cheaper to use drum brakes instead of discs but discs are better. And let's not even get started on that pinch bolt in the rear struts.
It's a tie between the 1992 Olds 88 and the 1999 Silverado with the 5.3 L engine. Overall, both have been relatively problem free.
You made me remember my 1993 Toyota 4WD Pickup, reg cab, 22RE, AT. Built right here at Fremont. (GM, NUMMI, Tesla).
Battery lasted 10 years.
I gave it to my BIL almost 15 years ago. ODO died at 350K miles. Totaled twice I think. He just sold it to some gardeners.
Still in service, must have the better part of 500K miles.
I’ve owned both, the 89 Tercel drove until the chassis rusted beyond repair. You could hear the rear struts banging around over bumps. My current winter vehicle is a 1990 Toyota 4x4 manual. I stay on the lookout for a priced right old school Toyota 4x4 at all times. They just make for a perfect little truck. They are indestructible and bulletproof reliable along with being a joy to drive. You must treat the frame and whole under chassis every year. I do mine with woolwax/ fluid film. Love my yotas!!
That’s a hard choice between my 1994 Ford Econoline E-150 it and my 1989 Mazda B2200 both have been great the whole time I have owned them haven’t had to do any major repairs to either one and they are both very comfortable. Much more reliable than anything made today.
Now this I can also agree on with the van. I also have a 94 Ford e150 it’s my summer only baby. Found it 3 years ago with 19,800 miles on it!! Couldn’t believe it but after much research and crawling all over the thing it’s mint. 35,800 on it right now so I can’t say much about the longevity of it but it’s been reliable on many trips for 3 years now.
what engine/trans does yours have?? Mine is the 5.8l with E4od and 8.8 rear end 3.55 gearing.
My experience has been just opposite lol I have a 2001 Jeep Cherokee that the engine got hot after it turned off it ended up warping the block is what a Chrysler specialist told me we thought it was a head gasket but we were wrong.
Hot after you turned it off?? That baby had to be hot before you turned it off as well.what ended up being the problem if it wasn’t the head gasket?
1982 Datsun 720 pickup diesel
Bought new and still runs today.
I sold it at 420k miles many years ago.
I think my wife's car might be our most reliable. 9 years, 215k, and it's had a flat tire for unscheduled repairs. As far as repairs I could schedule, I have replaced the battery, pads and rotors, and that's been it. Everything else we've owned has had to have a tow or otherwise was disabled in the driveway at least once in its lifetime, which meant it was down for longer than it took to change a tire.
Everyone hates HyunKias but I've had five of 'em with no real problems. Can't say that for any other brand.
Gave my 2009 Elantra to my son when he went to college. It had 67,000 miles. He still drives it and it has 212,000 miles and has been bulletproof. Hyundai and Kia make great vehicles.
1979 Chevy Caprice sedan, 305 ci V-8. Had it 10+ years with few problems. I did find out that the water pump could be changed on the side of the road without pulling the radiator.........in nowhere Mississippi.
My old 1998 Honda Civic LX Sedan. Bought it woth 106K miles and sold it with 340K miles. It never left me stranded in all those miles and from what I hear the car is still going strong now with over 400K miles in it,
