Put it right next to a nuclear power plant.Well ya but it's energy intensive, expensive, and we're talking 23M people.
Build a couple.
Reminds me of "Franco" in "The Dirty Dozen".... "That's what they want! THAT'S WHAT THEY WANT!!!".......... f what people want and grow what is reasonable.....
You might want to research that a bit deeper.Other crops aren’t as intensive, can’t continue dumping 90% of your water into a pit.
Funny part is many crops are functionally made illegal by lack of water, state could remove head from ass and be pro-active about land and water management with the main users of water but typically full stop only when they run out.
You are quite right in that with the water rights agreement, that water would just be used elsewhere, as they are entitled to a specific volume of water, even if it isn't sustainable in the river's present condition. That would have to change (the regulation) before any sort of recovery for the lake would be able to take place.You might want to research that a bit deeper.
Almonds use between 8-10% of irrigation water in CA. And yes that is a lot of water. But alfalfa, for example uses more water. And if you kill almond production - this water doesn't suddenly become free, it goes to other crops. Makes no sense when almonds are such an excellent source of nutrition.
I find some of the reactions here evirocrowd following and not well thought through.
https://www.sciencedirect.com/science/article/pii/S1470160X17308592
This statement is incorrect.
That’s nearly all California Agriculture. Given that a large percentage of America’s fresh fruit and vegetables come from California, that’s not a particularly practical, or realistic, suggestion.If they don’t natively grow there without irrigating, shouldn’t be allowed.
Almonds are the most energy and water intensive crop in California
Sure. Right on top of a fault line. Take your pick!Put it right next to a nuclear power plant.
Build a couple.
Ah, the Imperial Valley. Spent so much time there - look closely, you’ll see NAF El Centro on the West side of all that green.The Imperial county gets all its agricultural water from the Colorado river. They built a canal that runs from the river to the Valley alongside Intersate 8.
View attachment 111256View attachment 111257
Now that would be silly. I'm certain there are ways to transport either the water or the energy to a safer place.Sure. Right on top of a fault line. Take your pick!
This really does seem like a no brainer when you see all that water just sitting off the coast.IMHO, the answer is desalination for CA agriculture and torpedoing that water rights agreement. The watershed can recover, Cali gets to stop worrying about water availability and a more resilient and long-term solution is implemented.
Wouldn't we need significantly more electrical capacity to run desalination plants? I believe that uses massive amounts of energy.You are quite right in that with the water rights agreement, that water would just be used elsewhere, as they are entitled to a specific volume of water, even if it isn't sustainable in the river's present condition. That would have to change (the regulation) before any sort of recovery for the lake would be able to take place.
Right it would be silly. SoCal is the big beneficiary of water from the Colorado so it would make sense to build the plants there, but you can't put a nuke in SoCal in part due to seismic concerns which is why I posted the map of the various fault lines in the area.Now that would be silly. I'm certain there are ways to transport either the water or the energy to a safer place.
Glad you're thinking, though.
Diablo Canyon and SONGS were both fine where they were placed. Water is transportable, and so is the power, there are options.Sure. Right on top of a fault line. Take your pick!
Yep, shouldn't have retired SONGS...Wouldn't we need significantly more electrical capacity to run desalination plants? I believe that uses massive amounts of energy.
I agree it's the answer.
The aquifer below me fills very soon after a big rain. The state pumps water from the aqueduct into the Mojave river to recharge the aquifer if needed. Takes 3 days. Sure some may take longer.This statement is absolutely factual based on decades of scientific research.
Many aquifers take hundreds or thousands of years to renew the water.
It IS mining. It IS extraction, to draw water from them as the water in them now will not be renewed.
The Oglala aquifer is but one of them.
Read the article I linked. From 12 years ago. This is a well understood problem…sorry…couldn’t resist that…
It may not be true for your well, but it’s true for millions of people. True for many millions of people in the Front Range of Colorado as many municipalities sink deeper wells.
Well of course they're fine up until the moment the big one hits. Although Diablo risk was really really low. In any case it's not like the state is going to be building new reactors any time soon.Diablo Canyon and SONGS were both fine where they were placed. Water is transportable, and so is the power, there are options.
It's basically run through a giant Reverse Osmosis system. Like the ones they install under your sink. Only giant size. The biggest thing electrical consumption wise are the pumps.Wouldn't we need significantly more electrical capacity to run desalination plants? I believe that uses massive amounts of energy.
Some take several thousand years.The aquifer below me fills very soon after a big rain. The state pumps water from the aqueduct into the Mojave river to recharge the aquifer if needed. Takes 3 days. Sure some may take longer.
I can't verify your statistics, but I don't disagree. But to your nutritional quality point, growing RICE in California is foolish beyond imagination. Drive up to far northern California. The extent of the rice industry is shocking. Completely flooded rice fields for as far as the eye can see.Almonds use between 8-10% of irrigation water in CA. And yes that is a lot of water. But alfalfa, for example uses more water. And if you kill almond production - this water doesn't suddenly become free, it goes to other crops. Makes no sense when almonds are such an excellent source of nutrition.
