Originally Posted By: Chris Meutsch
Originally Posted By: Quest
Fred: My gaskets have hardened and now are leaking oil.
Bob: Why Fred, try this magic elixer! It's the BEES KNEES! It cleans, it swells, it's like new engine in a bottle!!!
Fred: My mechanic told me I need new gaskets?? They are $30.00 and two hours to install. Going to run me like $150.00 total!
Rob: Naw Fred, just run XtraSuperPMAXXXX Life oil! It'll swell those gaskets like Rita McNeil's maxi pads during her heavy cycle... Oh wait, every cycle is "heavy" for her! HAR HAR HAR!!!
Fred: Well, I spent $30.00 on the XtraSuperPMAXXXX oil change. It was still leaking. So then I went and spent another $30.00 on the special elixer. And it's still leaking. So now I guess I have to get it fixed?
Rob and Bob: ......... Maybe you didn't run it long enough? You need another cycle!
________________________________________________________________
Why is it that the RIGHT way of dealing with gasket and seal leaks is so looked down upon?
You REPLACE the gasket. Problem solved. Yeah, it is probably going to cost more. Yeah, it is a lot more inconvenient. But it FIXES the problem and isn't some half-assed temporary solution that isn't going to hold up.
Gaskets deteriorate (especially cork ones) and seals harden. There is no magic formula that is going to restore them to like new condition. You are just prolonging the inevitable and spending more money doing so.
I fail to see why the correct, and guaranteed not to fail solution is always pushed to the side for some half-assed "fix" that is temporary at best.
LOL Overkill ! Your comments make my day!
Too many a time I see folks here resort to 10-min gratification in-a-can or OTC instead of properly fixing the problem. And when those solutions fail to properly remedy the problem (most likely they will not, for the nature of the problem requires prompt solution), they post all over the place crying foul about s0-n-s0 OTC/10-min gratification in-a-can failed to even make his wife smile, letting alone fixing the leak.
IMHO cut the crab and just deal with the root cause of the matter: if it needs a seal, replace a seal; if it requires a full V/C set with spark plug tube gaskets (or doughnuts), cut to the chase and fix it. Don't just fool with half-ash monkey jobs in hopes of slowing down the problem.
Good riddance!
Q.
FINE. I'll get it fixed. I really want to do it properly anyway. Problem is my mechanic is expensive but won't screw me.
Mortgage, I'll be in touch. Right now, just sit tight and don't be more than 3 months late.
Chris:
I just want to make sure you understand my comment was not directed at you.
Whenever somebody has a problem that has to do with a gasket or seal leaking, it seems 15 people chime in rhyming off different products that they can dump in their oil that "will fix it". But of course, even if they DO stop the leak, the effect is only temporary.
There seems to be some sort of issue with doing it right. Otherwise, I wouldn't have been the only guy in the thread (with the exception of the one guy that agreed with me) recommending the correct solution.
That's exactly the problem, no one wants to fix their car the right way anymore.
It's all about cheap fixes.
I agree though, replace that gasket!
