Originally Posted By: jtaylor
thanx 94max, will do! the problem is, i have seen several results of tests saying that braking surface temps are up to 150 degrees cooler when drilled rotors are used. or is this all [censored]?
So you are saying,
get a really good, high friction, highly fade resistant pad, high performance fluid, and that should clear it all up? how about ss brake lines?
Slotted rotors came out to help dissipate the build-up of gasses from the pads. Today's pads do not off-gas like they used to, so I don't think there is any advantage to slotted/drilled rotors anymore. Besides, many pad designs these days have slots to help with this problem. And I hear of many drilled/slotted rotors cracking. I also think SS lines do not help that much, more for just looks.
Lots of info about this, here is just one link...
http://www.honda-tech.com/showthread.php?t=1437513
So you are saying,
