One man bleeder.
Cheap and very easy to use.
Available at your local auto part store.
They usually come with a variety of adaptors to connect to the bleeder screw in case the tube does not just slip over the screw end tightly.
When you loosen the bleeder screw, the fluid will flow out the hole in the center of the nipple.
Here is a picture of one set up and in use.
The bottle is placed slightly higher than the bleeder screw.....this way, when you pump the brake pedal, the fluid runs out, filling at least a big enough section of the tubing that when you release the brake pedal......ONLY fluid will be drawn back into the caliper, no air.
Connect the tube to the bleeder screw.....loosen the screw
A couple pumps of the brake pedal is all it takes to fill the bottle......then you tighten the bleeder screw......and remove the bottle to empty it.......repeat the process until the fluid coming out is clean.
The fluid in that bottle is clean fluid......
Here is what the first bottle you pump out may look like (I have seen worse)
A good aftermarket rotor is Raybestos "Advanced Technology".
They have 3 price points, Service Grade, Professional Grade and Advanced Technology.
Advanced Technology is their premium (best of the 3) grade.
For a aftermarket ceramic pad, I have liked Akebono.
Rockauto website has some good prices on brake rotors and pads.
You will notice that "Ceramic" is available in a wide variety of prices......not all Ceramic pads are created equal.
I would stay away from drilled rotors as the drilling removes material and can weaken the rotor.....leading to cracking in the rotor material under high heat conditions.
One thing that DID help my brake performance on a vehicle (after I had tried fluid/rotors/pads/calipers)......the flexible brake hose that connects from the caliper to the hard line.
They were not expensive and were easy to change.
I just got the Raybestos OEM style (none of the stainless steel "mesh" [censored]) from Rockauto...and they did the trick for me.
It was on an older vehicle, and even though they looked good,they were either broken down inside (restricting flow) or expanding very slightly when I pressed the pedal.
I am suspecting the first......either way.....they needed replacement.
