Techstream on a Mac
ME
How are you guys running this on a Mac? For the life of me, I can't figure it out. (It's a Windows only program, for those who don't know.) I know that Windows can be installed on a Mac, but I also know that a virtual machine will work. So...I've managed to install VirtualBox, but I'm pulling my hair out trying to figure how to run a Windows program. I was hoping I could drag Techstream into the VirtualBox, but no...I'm lost.
VirtualBox creates a "virtual" space on you computer so you can install an operating system such as Windows. Which enables you to run it as if it's own little program.
The thing that comes closest to what your trying to do is WINE for Mac. It's an open source "windows like environment" to run windows programs. However it is not Windows and since your not using typical program used by the masses it will likely fail. Your best bet would to be to bite the bullet and use Windows.
VirtualBox requires you install a copy of windows first within it then it works as regular windows. It is more tax on resources of system if you don't have extra RAM to support it.
The best integration I used daily at work is called Parallels. It installs Windows as part its normal install and acts like your Windows application is a MAC application if you want. The desktop and other folders are shared between Windows and MAC. If your MAC is lower end of processor and memory (I have MBP 2017 with 128GB 8 GB RAM/$1100 ) and the performance is quite amazing. Unfortunately its a paid for product but has a trial.
The best "free" solution is Bootcamp - no virtualization layer, which could mean less issues with the VCI. I was a fan of VMware Fusion on the Mac. Parallels worked OK when I used it 10 years ago on a WhiteBook. I feel any VM platform for a Mac can use a MacBook Pro with an Nvidia or AMD GPU to help it out a bit.
