- Joined
- Aug 28, 2006
- Messages
- 2,330
I could not find the thread I read for reference. A long-time member recommended Techron or Regane HM to help cure OPE carburetor issues.
I'm skeptical (to say the least) of following advice given on this forum but I have to say it worked.
I have a 12 y/o Echo string trimmer with hard start issues and it would only run wide open.
I poured out the gas, added Techron, ran it as long as I could (which wasn't long considering it was almost pure Techron in the tank), let it sit while I did other yard chores, and went back about 30 minutes later.
Started hard as always. Had a bad smell that I assumed was the Techron, and it smoked a bit. I ran it WOT for a while and when I let off the throttle. It idled! Now it runs great, starts easier, and idles again.
I did the same to my Stihl leaf blower which was not having problems but figured it wouldn't hurt then poured the rest in the tank of my tractor.
From now on, I will use Techron as my annual maintenance on my OPE.
Thanks to whomever it was for mentioning this.
