Decided to "tune up" my Ryobi CS30 string trimmer, aka weed whacker. I've not started it in 2 or so years. Everything I could see looked good and clean, the factory Champion spark plug looked great. I was curious if it would start and run. There was not enough old fuel in the tank so I added fuel/oil mix that was at least 2 years old. I did add FP60 to the fuel/oil mixture initially. It started and ran fine as long as I held the throttle open. It would stall on idle at first. The longer I ran it the longer it idled. It ran strong and didn't smoke at all. I'll use up the old fuel and get fresh fuel when it runs out. Most likely adding the FP60 helped to stabilize the fuel/oil mixture or I got lucky. They do sell ethanol fuel treatments for OPE, Stabil makes one. Now I have to revive my, not run in years, power washer. It has a B&S engine. That should be challenging
Whimsey
Whimsey
