I drive a 1996 Saab 900S (normally aspirated 2.3 liter 16 valve engine) which is impeccably maintained and driven in a "spirited" fashion less than 5% of the time.
My car (as all Saabs, whether turbocharged or normally aspirated) is rated for 87 octane gasoline.
I have, on occasion, used higher octane gas, but I travel alot on business through parts of the country where I perceive that it's better to buy cheaper 87 octane (as it has higher turnover in sales, which I believe corresponds to a lower likelihood of contamination from sitting in the tank at the gas station.)
In any event, I had recently been hearing some slight detonation when the car is lugging down low in first gear during hot weather, while running the a/c. I immediately began using premium to alleviate this situation, but I was eager to return to 87 octane gas, so I began to troubleshoot various things. The spark plug gap was checked and verified to be within tolerance. That led me to my next step, which was to try and get rid of any combustion chamber deposits whch might be causing the problem.
A tankful of 87 octane Chevron gasoline, with a large bottle (good for treating 20 gallons) of concentrated Techron in my 15.75 gallon gas tank, and all detonation is gone.
Completely gone.
This is amazing - I knew that these solvents were powerful, but I had no idea that a single tankful would make such a difference.
I am now a confirmed Techron fan - in fact, I'll research this forum for awhile to learn if there might be something even more effective. But in the meantime, I'll be adding a big bottle of this stuff to my tank at every oil change (5,000 miles.)
This stuff really works for curing detonation.
Completely gone.
